Status
Not open for further replies.
1 - 2 of 2 Posts
My Sony is sick, as referenced in another thread. Picture will roll horizontally on 1080i sources. It will "shred" digitally on 480i, and it will turn to digital garbage if I zoom on my PVR while watching 1080i. I've narrowed it down to a loose connection on one of the cards inside. If I pull the card to one side, the picture comes back completely clear. For the life of me I can't find any bad solder points on the card itself, but I suspect the socket it fits into may be the problem.
Burke Electronics (allav.com) quoted me a flat rate of $350 to fix it at my house. They didn't think it needed any parts, just some soldering. They guarantee their work for a year. Is this a fair price for the work? Are there any other shops I should consider? Thanks for all inputs.
I think that's a fair price for a house call. You certainly don't want to carry this HEAVY TV to a local repair shop. The technician will require some time to identify the root cause. And the one year warranty is a good investment because these sorts of problems can pop up again.
1 - 2 of 2 Posts
Status
