Originally posted by xris2o0o:
Maybe this isnt effective yet.. it could still be getting debated over.. i think all these manufacturers would of put out something by now if it was happening right away.. not even the newest ones that i know of have it.. so thats gotta tell u something
chris |
What is still being debated? Here is the verbiage right from the adopter agreement the content providers and equipment makers are signing. This is the contract they are agreeing, you can stick you head in the sand and hope, but here are the facts.
Brian
quote:
“Constrained Image†shall mean an image having the visual equivalent of no more than 520,000 pixels per frame (e.g., an image with resolution of 960 pixels by 540 pixels for a 16:9 aspect ratio). A Constrained Image may be attained by reducing resolution, for example, by discarding, dithering, or averaging pixels to obtain the specified value. A Constrained Image can be displayed using video processing techniques such as line doubling or sharpening to improve the perceived quality of the image. By way of example, a Constrained Image may be stretched or doubled, and displayed full-screen, on a 1000-line monitor.
quote:
4.3 High Definition Analog Output. Licensed Products shall not pass Decrypted DT Data to a High Definition Analog Output, except as set forth in this Section 4.3:
4.3.1 Licensed Products may pass Decrypted DT Data to a High Definition Analog Output as a Constrained Image.
4.3.2 Licensed Products that recognize and respond to the Image Constraint Token in accordance with the Specification may pass Decrypted DT Data to an output in High Definition Analog Form when authorized by the setting of the Image Constraint Token.
4.3.3 Licensed Products incorporated into Computer Products may pass Copy One Generation or No More Copies Decrypted DT Data without image constraint to SVGA (1024x768 and greater), XGA(1024x768), SXGA and UXGA or similar computer video outputs that were widely implemented as of May 1, 2001 (but not to such typical consumer electronics outputs as NTSC, PAL, SECAM, SCART, YUV, S-Video and consumer RGB, whether or not such outputs are found on any Computer Product) in High Definition Analog Form for devices manufactured prior to December 31, 2005, unless otherwise
notified by DTLA.
4.3.4 Licensed Products may pass Decrypted DT Data in High Definition Analog Form to a High Definition Analog Output where such Decrypted DT Data is encoded Copy Freely.
Read the entire agreement here.
http://www.dtcp.com/data/DTCP_Adopte...ment010730.PDF
