1 - 20 of 77 Posts
who cares??? haven't we put bitstream vs PCM to bed yet?
Discussion Starter · #6 ·
Bitstreaming Dolby HD allows someone to use the high quality DACs in their high-end AV processor, and to apply DSP effects to the signal. It doesn't always matter, but it can...and don't forget the pretty light comes on.
Discussion Starter · #8 ·
Bitstreaming Dolby HD allows someone to use the high quality DACs in their high-end AV processor. Hasn't anyone ever heard a high-end AV processor with quality DACs like the Burr Brown PCM1796 DACs in dual differential configuration? There's nothing better right now.
argh, this is why this subject drives me crazy.
Using PCM would still use the DAC's in your processor since PCM is digital.
And, you can still apply DSP to the signal.
Banned
Yeah but you wouldnt light up that teensy weensy light on your fancy smancy AVR
Discussion Starter · #12 ·
elvisizer,
There's error correction to Dolby HD that takes place to keep the integrity of the bitstream source until it's decoded, but PCM can be modified along the way because of jitter.
So it's got a jitterbug?
Originally Posted by peterpioli /forum/post/17021370
elvisizer,
I bet you a million dollars in a blind test, you could not tell.
elvisizer,
as Goatse pointed out, jitter causing audible issues is extremely unlikely.
Also, i've yet to see anyone do a test that demonstrates that PCM streams are more susceptible to jitter in the real world than bitstream. Do you have a link showing that?
1 - 20 of 77 Posts
