Status
Not open for further replies.
1 - 2 of 2 Posts
My new sony receiver has a cable to control vcr operation. One end plugs into the back of the receiver. The other end has 2 wires, each going to an head that communicates with the vcr remote pickup. Why are there 2? Does it matter which I use? What do you do with the other head?
thanks
Well, I just used the single one from my A55, but I would guess is that it will extend control of the TV, since it is the only other device that it can be programmed for. (I thought that the dual ones were usually for cable box/VCR setups.)
Keith
1 - 2 of 2 Posts
Status
