1 - 4 of 4 Posts
I was thinking about getting the Sony RM-VL600 Universal remote to control my Kenwood receiver, Phillips TV, and Oppo DVD player. Since the Oppo brand is fairly new and obscure, has anyone used this Sony remote with the Oppo?
I have the Sony VL710 and it's very easy to learn commands. You basically enter the "learn" command sequence, pick which button on the Sony remote you want to map the command to and simply aim the original remote at the Sony and press the button. You'll get either a confirmation that the command was learned or not.
My VL710 had very good instructions, so I imagine the the VL600 would have the same.
1 - 4 of 4 Posts
