Status
Not open for further replies.
1 - 2 of 2 Posts
I have spent DAYS trying to find a source for the expansion cup on the 7" CRT for a Sony 41" with 180DLB22 tubes. Any sony for the last 5 years uses these rubber cups to allow for thermal expansion of the glycol coolant. Sony WILL NOT provide a part #. They say replace all 3 CRT's! Not an option. The Phillips 313501301060 cup will work, but is not an exact replacement. ANY help will be greatly appreciated! Reply to : [email protected]
Mike-
You might check your local TV repair shops. If they service "Big Screen" (Sorry, I couldnt resist. No such thing until you go FP) RPTVs they probably have a few boxes sitting around with tubes and no boards. Perhaps they will part with the cups. If you look long enough you will surely find what you need - you would be surprised the number of chassis the shops I have worked for tossed out back for the trash, many with perfectly good tubes still inside...
--Kieth
1 - 2 of 2 Posts
Status
