1061 - 1080 of 2253 Posts
Premium Member
@Alex F. @JoeKustra
Thanks for your help
One more doubt and question.
Did you test your BDPs using ordinary/standard CDs or SACDs?
Perhaps this noise appears only when playing standard CDs. I did not test any SACDs, only standard CDs.
Could you test this please??
@JoeKustra
Do you say that S6500 is the best choice in terms of audio/video capability?
Does it offer everything BDP-S6200 & 7200 offer? Or something is missing?
How about decoding DTS-HD Master Audio and outputing all channels?
How about DSF, DSDIFF, AIFF, and ALAC playback?
Thank in advance!!
Regards.
IMO, the 6500 is just a smaller version with new UI of the 7200/6200. I own the 7200 as well, a 1200 and 1500.
  • Like
Reactions: em-avs
@Alex F. @JoeKustra
@JoeKustra
Thank in advance!!
Regards.
No problems, but I see Gracenote isn't working again. I play music but I only know about mp3, cda and wav formats. Other than that I leave it to the HTPC crowd. I do copy my CDs and use copies in my car. I have an S6200. I got the S6500 because of better CODEC for wav and Pandora's screen saver is broken on the S6200. In this country the S6200 and S7200 are the same internally.
Only Blu-ray audio that I can't test is Atmos. Nothing else has ever been a problem. I feed a Yamaha RX-V867 7.2 that is several years old.
Select EDIT. The look to the blue DELETE box. It needs another check and your post is gone. In under a minute you won't even see the editing message.
@Alex F. @JoeKustra
I used standard CDs to answer your original question.
  • Like
Reactions: em-avs
...the remote control that comes with the BDP-S1500 doesn't have numbered digits on it, which means I can't enter the five digit code...
If the spelling method posted earlier doesn't work, you have several other options.
- Use the smartphone sony remote control app
- Use any old Sony BD remote from any model (all Sony BD codes are exactly the same since the beginning of time)
- Use a universal remote (they start at $3 on ebay)
- If you have cable TV, that remote will work if it has DVD code 1516 (21516)
I've got to watch this movie sometime to see why it's worthy of watching over and over. You're not the first person I've seen in these forums where this is the first disc they play when they get a new player.
S570 remote has numbers. I still use it. RMT-B107A
Can anyone please confirm wether the S5500 can decode 5.1 DD+ to Multichannel PCM? After searching through this thread it seems like the "auto" option will do it, but i need to confirm wether this is true or not before i purchase one.
Premium Member
I believe not the last one to decode both multi channel DD or dts codecs to pcm was the 790. The 7200 does multi channel dts over Pam but DD just 2 channel the 5500 and 6500 I believe both 2, channel Pam. Please someone correct me if I am wrong.
Does anybody have any idea how to type into the BDPS6500 when trying to search Youtube? There is no provision for typing a space using the onscreen keyboard, so I type 30+ consecutive letters and numbers like an idiot and wait for God to reach down and parse the words out! I can't find instructions anywhere for typing into it!
Many thanks for any help!
Also - I plugged a USB Keyboard into the front USB slot, but I still can't type into the blasted thing! Anyone know how to set up a keyboard on the player?
I just tried a YouTube search on my Sony, and there is a huge space bar at the bottom of the on-screen keyboard. You can also use a couple of smartphone apps.
If you have a smart phone or tablet (iOS or Android), use its YouTube app to search instead of on the player. There are two ways to sync the search result:
1. If you let your player sign into your Google account, it will sync the playlist and history from the smart device to player.
2. Simply use the cast button on the YouTube app on your smart device to send the video to your player (you don't even need to launch the youtube app on the player, nor sign into your Google account).
There is also a Sony remote app for iOS with full qwerty keyboard. But the youtube app is better and built in.
Space bar works like a space for me. You can't really tell it's done anything until you pick the next letter. You use the button in the middle of the arrows to select letters and the space.
When I try to use that "spacebar" thing, it acts like the Enter key. What apps? I have an iphone.
It "|____" key performs the actions of both Spacebar and Enter commands. Press the "|____" key after typing the first word in the search box and search results will be displayed as if Enter was pressed, but then go back up and start typing again. There will now be a space.
I have had an LG BD player for some time, but it recently broke. I decided to get the Sony BDP-S1500. Today it arrived and I have been playing various BD's on it.
While I am very impressed with its performance, I do have one issue that I am hoping someone can help with.
The problem is this: One of my BD discs is the Skynet Edition of Terminator 2. As anyone who owns this disc knows, there are three different versions of the movie on the one disc - the cinema version, the directors cut and the directors cut with alternate ending.
Where the cinema version and directors cut are easily select-able, the directors cut with alternate ending requires a five-digit code - 82997 - in order to play.
There's just one problem: the remote control that comes with the BDP-S1500 doesn't have numbered digits on it, which means I can't enter the five digit code, which means I can no longer watch the directors cut with alternate ending.
If anyone else has this BD player and the Skynet Edition of T2 on BD, or if anyone else can offer any help or advise then I shall be vert grateful.
1. Under "Select Version" in the main menu, navigate to where the code needs to be entered under "Select Special Edition".
2. Press the Options button on the remote. Scroll all the way down and select "Number Entry".
3. A black square with a hyphen in the middle will appear on the upper right hand of the screen. Use the up and down keys to scroll through the numbers and enter the code.
audio question
I just set up my new 6500 and am having major difficulties understanding the audio part. It's connected via hdmi to my projector, and I tried to also connect to my 2 channel speakers via a coaxial cable, a digital-analog converter (Portta PETDTAP) and then red/white composite to a single mini-plug that goes into one of the speakers. I tried to play "The Avengers", but in the default 7.1 audio all I got was loud static. I remember reading that this technology won't convert, but that 5.1 will. I did get audio when I switched to the 5.1 option, but for some reason it was a descriptive audio that also explained what what shown in addition to the dialogue. ARGH! There was no way to get 5.1 with the normal track. The French and Spanish options worked fine too. Odd. I wonder how many blu-ray movies are set up that way. So then I tried my regular DVD of Chungking Express which gives no option other than the 2 channel Chinese audio, but I got loud static on that as well. So I'm super confused. Shouldn't that work fine? I'm returning the coaxial cable and D-A converter to Amazon, but I don't know if it's a problem with that or something more fundamental. In all cases I get audio from the projector itself but it's very soft.
Any enlightenment or direction about where I can read up on what to do would be really appreciated. I'm anxious to get this set-up properly and be able to watch some discs in addition to streaming via my Roku 2.
thanks very much.
thanks very much.
A possibility is that the player is outputting digital audio formats that your DAC doesn't understand. Make sure that the Audio Setting for "Digital Audio Output" is set to "PCM". The default is "auto" which usually passes through the original multichannel audio soundtrack.
