1 - 20 of 40 Posts
Just got this AVR hooked up today. Nothing specific to say about it but I already know I'll have umpteen questions. Surprised there isn't a thread already.
So far, after just a quick review, the settings are frustrating to say the least. Too damn many options for my taste. Do I assume that if I run Auto Calibrate that all other settings are moot? I also find it VERY frustrating that I can only manually set speaker output levels via the GUI. My old AVR let me do this on the fly while watching a movie so I could actually hear the difference as it was occurring. Unless I'm missing something, you have to stop viweing, enter the GUI change the setting and then go back and see if you like it.
It would be better if you could change speaker settings on the fly. However I do like the GUI and it does not bother me the way it works. Have had my receiver now for 3 months or so and am very happy with it. I think it sounds great with both movies and music. No complaints at all so far.
Replacing a Pioneer VSX1014-tx from 2004. Had a problem with the digital inputs for the first time this year. Apparently, this was a common issue back in the day, but I haven't had any issues.
The DN1000 appealed to me due to the 7.1 channels (I have a 6.1 setup, which it recognized and appears to handle), and the 4 HDMI inputs. The Pioneer was freaking 38 lbs, a huge beast. The DN-1000 is much lighter, which I'm not taking as a good sign. I haven't cranked it up yet, but it seems to be putting out enough power.
I am not clear on the surround options. It appears to be processing Dolby Prologic IIx, but need to see if I can force some Dolby TrueHD at some point. The AVR appears to have some capabilities that I am not taking advantage of at startup.
The GUI is fine, in fact, I feel like it it's mostly easily maneuverable. The ACC setup worked great...it recognized all of my speakers and sub, and set up appropriately. I went back in and messed around with the setup, and then reran the ACC setup a few times, and it makes the right choices every time. The distance measurements were spot on.
Had a little trouble attaching the Wii, but I think it was self-forced. I tried to run it through the BD input for whatever reason, but once I connected a component set and put the sound through the "TV" input, it found the component input and assigned the audio correctly.
Will be hooking up a Brite-View Cinematube and a PS3 tomorrow, we'll see how it all shakes out.
One note: I did go back into my TV's settings (a Toshiba HM157) and cleaned up the brightness and contrast. Not sure if or how the AVR output anything differently than my previous set up, but the whites were very bright, and had to tone bright/contrast down once I got it hooked up. I will look at these during Call of Duty this weekend, and may need to up them again.
So in summary, I'm OK with the purchase. It's definitely not a mid-tier receiver worth $500, but got mine for $319 and think it's probably worth it. One quality note...the front door is the cheapest plastic they could find. You would think for a model a step up from their 800, they could have spent another six cents on this part. My AVR is in a cabinet so I won't be fixated on it, but just an odd place to save a few cents.
nice thinking of getting one for the bed room.
IMO the door is not that cheap. I have only touched it once to remove the packing tape that held the door closed in the box it came in. After reading your post I revisited the door and it is just fine by me. It is really a non-functional door for me because I do not have any reason to access the buttons and inputs behind it.
I got one of these from a guy on craigslist this weekend. 1-week-old but otherwise new out of box. $300 cash.
This is an amazing box, considering before I was using a pretty terrible receiver. I am loving the simplicity of having just HDMI cables. I haven't used many other receivers, so I can't really compare, however I'm happy with my purchase.
I also just go this to replace a Pioneer VSX1014-TX. I'm running it with a PJ so i really wanted to use the HDMI without having to use a switcher i've been using from monoprice. Just set it up last night and i love it! Like it was said, the Pioneer was close to 40lbs and just plain huge, this thing is much easier to deal with. The GUI is pretty crappy which i found surprising. I have a Bravia, a PS3 and a Sony BluRay player and all have nice menus, this not so much. The speaker terminals also feel kind of cheap. My speakers use banana plugs are are 12GA and seem to bend a little bit.
I will work on getting her tuned up this week, all i did was run to auto cal and changed the speakers to small for right now, had to get going to catch the pacific!
Hi, Just purchased the Sony DN1000. I have a Comcast cable box and PS3 hooked up via Category 2 HDMI cables to the receiver and then the receiver to my Samsung Plasma via Cat 2 HDMI. My problem is when I try to play HD content from OnDemand I get a No Signal from my TV. This doesn't happen with SD content only HD. I tried hooking up the box straight to the TV and it works fine.
The cable box is a RNG110 from Comcast. I have the box set up in HDMI 1. If I play the HD content from OnDemand it shows No Signal. Now if I hit HDMI 2 or any of the other input buttons and then go back to HDMI 1 it's playing and it looks great. I'm real glad I got it to play but not sure if this is normal???
I found a link to the manual for this box and didn't find any reference to HDMI 1 and HDMI 2.
I forgot I am actually using the component input to the receiver and before that it goes through a sling box connection. The time warner box doesn't seem to like the HDMI output and the Component output used at the same time, but it is better about this if a receiver is used. I will try the HDMI again when I have access to the back of the system.
I output everything from my cable box as 720p. If you match this with a 720p resolution on the receiver you will probably avoid the problem. In your settings you should see an area where you can output everything as 720p by turning off all the other resolutions. On the Time Warner box this upscales anything 480p/i to 720p, and de-interlaces 1080i to 720p.
Hey, Thanks alot. I changed the resolution on the RNG110 to output 720 and it worked. I don't have to change the HDMI on the receiver. I went back into the box settings and then clicked on 1080i and 1080p 24 pass-through and it is still working. Also found out I had to put some tape in front of the eye on the cable box to get the remote to work right. It was running real slow and the Guide and OnDemand were freezing up... Thanks again.......
Question for you all, i got it and everything's setup. I ran the auto cal, changed the speakers to small and crossover at 80. Verizon Fios ran though HDMI and when you watch HD/5.1 it sounds amazing. As soon as you hit a stereo source though (commercials, SD) the sound all of sudden becomes like a tin can in a bathroom. It's almost like it's forcing the 2.0 sound into 5.1, but it sounds horrible. Has anyone else ran across this? I know it's gotta be a simple setting but haven't found which yet.
I have been pretty happy with mine even though I am going to sell it for a 3d receiver in the next few months. Only things I don't care for is not having a real way to mess around with the subwoofer. You have to set the speakers to small and use that to set the crossover settings.
I got this unit for @279.99 from amazon on black friday so I can't complain to much.
That is the way I do it. The GUI is slow but once you get it set up good you won't be messing with stuff that often. When I first got mine I was constantly going back and adjusting my crummy sony center channel. I have to keep the sucker cracked up to +5 just to keep up with my towers.
1 - 20 of 40 Posts
