Status
Not open for further replies.
1 - 20 of 277 Posts
I received my STR-DA3000ES yesterday. The unit's street date was supposed to be the 1st of September, then Sept 15, Crutchfield says the Sept 31st, and then I was told October 15th by Tweeter and Abt electronics. Tweeter happened to have one in the warehouse that, according to the saleswoman at the store, was supposed to be for an in-store demo. It was NIB and she sold it to me for 10% off, which I don't consider bad for a unit that is hard to obtain.
This is not meant to be a true review of the 3000ES. I have had many people email/PM me asking me to post my impressions when I received the unit. I have not performed an A/B comparison of the 3000ES to my Yamaha 1400 or Jolida 1501RC integrated tube amp yet, so this is more of a 'features overview'. Once I spend some time with the unit and compare it to my others, I will post more detailed thoughts.
My associated equipment:
ACI Sapphire main speakers (86db efficient, so not an easy load)
Rocket RSC100 center (to be the new ACI center when Mike gets done with it.. :) )
Axiom QS4 surrounds
SVS 25-31
Music Hall CD-25 cd player
Sony 400 disc player (hey - the unit re-clocks and supposedly gets rid if jitter, so why not try a POS CD player).
Mits 55809
Hughes E86
DirecTiVo
Looks:
The unit is seems well built, although it is light since it does not need massive heat sinks. The front faceplate is thick and the knobs and display look nice. It is very a 'industrial' looking unit, which some people will like and some will hate.
Menu:
The menu system is graphical and moderately easy to navigate. Any section that cannot be currently accessed because of the mode you are in is grayed out. This is nice as when I was in two channel mode I could still see all of the menus that are available when the unit is in a surround format mode.
The menu is very easy to use from the display panel on the front of the unit. You can adjust everything you see from the monitor outputs on the LCD screen. This is nice because if I need to adjust a setting when listening to music I do not want to turn on my TV.
Remote:
To try and simplify the massive remotes that come with most receivers, Sony has tried to make a remote with less buttons. There are no direct access buttons for each source. If you look at the picture of the remote at Crutchfield, at the top just below the LCD you will see a button that is about a 1/4" wide. You push it up or down to scroll through the sources on the LCD. When you are on the source you want, you press the button in to select the device. I found it somewhat of a pain to use, as when I would push the button in I would accidentally scroll up or down. I have a Pronto so this is not a huge issue for me, but it might be for others.
The rest of the remote is fairly standard.
Setup:
The front speaker's distance is grouped together, so if one speaker is farther than another the manual states to set the distance to the closest to you. The adjustments are made in 1 foot increments. This is less detailed than the Yamaha 1400 (.5ft increments), but I am not really sure if it matters.
Speaker levels are easy to adjust. The sub crossover can be set from 40Hz to 200Hz (I think). I do not know of the unit performs bass management on the external inputs. I thought I read that it did, but the manual says nothing about it. I will be hooking up my DVD-Audio player tonight, so I will find out.
All of the digital inputs can be assigned to different sources.
According to the manual, there are three user presets that will save some settings. I have not used this feature yet, and the manual is not clear if it saves all settings (levels, xover, etc) or what exactly is saved.
Video output:
The unit transforms composite->svideo->component. When doing an up-conversion you can adjust the hue, sharpness, and color. I did not hook up my video components to the unit yet. I should be testing this out tonight.
Sound:
Ah, the important part. All of this was done with my 400 disc changer using the optical output. I will do analog vs digital comparisons later.
I was very tired last night, so I had planned on going to bed at 11 (I had the unit hooked up by 10). I didn't goto bed until 12.
FYI: When I listen at night, it is at low levels since my wife and baby are sleeping. I prefer soft, detailed music to a loud over-the-top wall of sound.
I was very impressed with the sound coming out of my speakers. The sound-stage had pinpoint accuracy and it was very wide. The unit has an almost-tube (almost) sound to it. The midrange was very sweet. Since I didn't do any comparisons to my other gear, it might have just been a good night for my ears or brain. I couldn't get over the fact that a receiver with the word 'Sony' on it could sound this good (I am NOT a Sony fan). The first time I really considered the ES line was six months ago when my Rotel dealer suggested I buy a ES receiver instead of the Rotel 1055 (he sells both lines). In his opinion, a cheaper models in the ES line do just as good as the Rotel for HT and they save you money. I still bought the Rotel, but had issues with it so it was returned.
This morning I tried LOTR. Dialog was clear, and it easily drove my speakers to insanely loud levels. I didn't get out the SPL meter yet, but it had no issues driving my speakers far louder than I would ever listen.
The bad:
I noticed one thing that will be an issue for some. I was going to hold off on posting it until I can further diagnose it, but it probably is not going to stop so here it is:
At high levels (-15 on the display, which goes to +5), there is a hiss from all of the speakers. It is only audible from 6-9" away from the speakers, but it is there (we are heading down the Outlaw 950 path... :)) At +5 it is audible from a couple of feet away. +5 would also destroy my speakers.
-15 is pretty loud. I had music at -40 last night, so it was not close to being an issue. LOTR was at -20 and that was louder than I would normally watch a movie, unless I was messing around or showing off the system. The hiss comes from all speakers, even if you are in 2 channel direct mode. It probably has to do with the S-Master Pro chip outputting to all amps even though only two are being used (just a guess here).
I have not tried analog connections yet to see if it is still present. I have also not tried unplugging other inputs, etc. I will do a little experimenting to see if I can get the hiss to go away.
Zone 2:
You cannot use the surround back amps for zone 2. At first I was annoyed with this, but then I realized it is probably because of the digital amps and processor. The processor probably cannot decode and output 2 signals at the same time. This is my theory anyway.
I will obviously do more listening and try out the other features and post a follow-up to this. If you have an questions, I will try to answer them.
Kevin,
Thanks for the early review. I am very interested in the new ES line. I had a salesman show me the now-discontinued all-in-one AVD-C70ES and was very impressed (I was reluctant to even listen to something that looked like it should be sold at Sears). However, I'm not sure it is flexible enough to serve as HT center (am hoping the new 700 may improve on this) and so I am looking at the stand-alones as well.
In addition to hearing your detailed review of sound/features, I was wondering if you could tell me how "hot" the unit runs. The all-in-one ran cool to the touch even after playing at some serious volume for awhile. If the sound/features hold up, this might be a tie-breaker for me in choosing a unit as I will house it in a cabinet and it would be easier not to have to get elaborate with ventilation concerns.
John
Discussion Starter · #3 ·
I have my gear in a cabinet with computer fans blowing in the equipment. You can see it if you follow the URL in my sig.
The 3000es was cool to the touch after two hours last night. Granted, I was using it at low volumes, but the Yamaha 1400 gets very warm when listening at low volumes.
There is one almost-warm section on the top of the unit. The transformer must be just below that section.
Over at audiocircle there is a lot of talk about the all-in-one units. They don't seem to have quite the functionallity to run an entire system, but they are supposed to sound incredible. The thread over there is one of the reason's I wanted to check out Sony's new digital amps.
I forgot to mention: I do think that after my A/B comparisons with the Yamaha and Jolida, if I decide to keep the Sony I will probably end up downgrading to the 2000ES. The only benefits that I currently see to the 3000ES are that the volume is adjustable on the 2nd zone, the component video upconversion, and a few extra watts. The volume in the 2nd zone dosen't matter since it isn't powered.
The manual for the 3000ES is also for the 5000ES, so the 2000ES might be missing more features. That will probably be the deciding factor if I spend the extra $200 on the 3000ES.
Kendrid, the 2000ES does not have preouts for all channels so you must have enough confidence in the 2000ES's internal amps.
Discussion Starter · #5 ·
Thanks - I forgot about that.
The 'digital' amps are the main selling point of these units, so if I decide to keep the 3000ES (or 2000ES) I plan on using the internal amps. Of course 3 years from now that might change, so the preouts might not be a bad thing to have.
Trinnov Alt16, Parasound Amps, Martin logan speakers, 120” screen, SVS subs and dedicated media room
How do you compare it to the sound quality in home theater to the Yamaha, I've been thinking of getting either one of those.
Thx,
Eric
Discussion Starter · #7 ·
stieger - I won't comment on that until I do some direct comparisons. YPAO vs the 'sound' of digital amps (and the 100% digital processing). I will also compare the Yamaha without YPAO. I will say that I often find it difficult to tell the difference between receivers with HT, unless one is horribly bright or has some flaw. Music is what sets components apart (for me anyway).
Also, for anyone wondering about Sony's 'new' digital amp technology, check out this review.
Then you look at the thread here called '$300 Krell Killer', and you start to see that people are being very impressed by this new line of amps and processing. The next few years are going to be interesting. Room calibration will become more advanced, along with digital technology.
Discussion Starter · #9 ·
Thanks for that link. I post my issue on that board. Hopefully it is isolated to the first run. If not, it could seriously hurt these units sales, even though they sound great.
I will try a DVD scene with only dialog to see if my hiss is audible.
Time to go listen to some music.
Discussion Starter · #10 ·
I hooked up all of my video through the unit last night. I noticed no noticeable loss in video quailty.
But, I am going to revert back to running everything into my TV. I use PIP/POP quite a bit, and I often listen to a CD while sports are on. I haven't found a way to listen to one source and watch another. I haven't read the remote control's manual yet, but I have tried every button and I don't see a way to switch video inputs without also switching the audio ijnput.
Music still sound great. Friday night I will be hooking up both the Yammie and 3000ES to a switch box and comparing two channel music.
Originally posted by Kendrid
I haven't read the remote control's manual yet, but I have tried every button and I don't see a way to switch video inputs without also switching the audio input.
On my older DB-940, there's an input mode button that toggles the input dial between audio, video, and second room inputs. I also see that button next to the knob on the crutchfield picture of the 3000ES. I suspect the functionality is there with that button, though obviously, without one, I can't know for sure. Also, on my DB-940, if I select a video input via remote, and then switch to an input that ONLY has audio input, only the audio changes, and the video still shows the old source... So, if you want to watch sports and listen to a cd, select your sat/cable box. Audio and video both switch. Then select CD. Because the CD input doesn't have a video input, only the audio switches. Now, if you play your CD's through your DVD player (which would have a video input), when you select DVD, the video would switch too...
Let me know if this works on your 3000... Also, it looks like the component video inputs are not assignable, correct? That would help with hookup flexibility.
Discussion Starter · #12 ·
That is correct, they are fixed to TV and DVD inputs.
Thanks for the info on the video switching. I will try it tonight.
Kendrid, I am debating between the 1400 and the 3000ES myself and would like to see how the amps in the 3000ES hold up and at what volume do you get them to clip. I have the Wharfedale Emerald 97s with a sensitivity rating of 87dbs and am very interested in reading your detailed report.
One think about video quality on the 1400 was I did feel that the quality on my Proton prepro was slightly better than on the 1400.
Discussion Starter · #14 ·
Nick - I should be able to push the 3000ES pretty hard this weekend. I can't at night because our baby is sleeping. The one time I have pused it with LOTR it did fine. I will get the SPL meter out next time and measure how loud it will go.
I also want to push the unit so see how noticeable the hiss is at louder levels. It is definetly an issue that needs to be resolved. Once more of these units are on the market we will know if all of them are affected or just a few. I hope it is just a few.
About heat: The receiver was on for about 6 hours last night, and when I shut it down the top was warm. This is in an enclosed cabinet with my cooling fans off. It is much cooler than any other receiver I have used.
Hi,
I am somewhat "inbetween" units right now - either deciding on the new ES line or the 2400.
Last night I went and picked up the 3000ES, and immediately after plugging it in, did the calibration to SPL 75dB. I turned on my DTV tuner, and immediately noticed the hissing sound you guys are talking about. Upon calling the dealer (Magnolia) the guy said, well sure, you're going to get that hiss at high volume levels (I still had it set to 75dB, which isn't very high volume at all), because the amp in the ES unit is a class "D" amplifier. The benefit is the digital amp doesn't need to warm up like a traditional mosfet amp, the negative is you'll have that hissing sound..."
So, I tried a DVD, played at a normalized 75db, with peaks up to 105dB, and that hissing was very present indeed. So much so, I called Magnolia and told them I was returning the unit. Totally unacceptable for a new reciever - regardless of price.
I returned it, and got the Denon 3803. No hissing, and sounds 90% as good as the B&K seperates (Ref 50 and 125.7) which I had set up in that room.
My room is 11ft wide x 19ft deep x 10 ft high, so it doesn't take much to get very loud. I'm powering an Atlantic Technology 450e THX speaker system, 8 ohm, 91 dB sensitivity, so they are quite easy for the amp to drive.
Anyway, I really like the Denon - just hate the old look of it. Anyone compared the Pioneer Elite "53" model? I don't think it would sound any better than the Denon, but I like the look of it (more classy).
Eric
Discussion Starter · #16 ·
YMMV, but I preferred the Elite 45TX to the 3803.
Why didn't you try the 2400 at home? I have been happy with my 1400 for HT, and it does well with music.
What your dealer said may be true, but until I hear of everyone having this issue and Sony doing nothing about it I won't give up on the unit (unless after A/B comparing it against the 1400 and Jolida it dosen't do any better). I've read reviews of 'high-end' digital amps and they don't mention any hiss. It could just be a manufacturing flaw on the first units. It is hard for me to believe that they would 'risk' their ES line's reputation with products that exhibit extensive hissing.
EDIT (update): Over at AudioCircle someone just confirmed that their all-in-one Sony 70ES unit is "dead silent". Edit 2: Another user just confirmed that their 70ES is "dead silent" also. Seems classD does not mean the amp must hiss.
I am going to pick up a AVDS50ES tonight to see how it compares to the 3000ES (mainly regarding noise).
Hi,
New here, but I have a 3000esssssssssssssssssssssssssssssss also.
I have experienced this problem, but did not return it yet. I had hoped it might dissssssipate after breakin. However, I may need ssssssssssspeech therapy if this doesn't change soon. Pushing the "Direct" button behind the front panel hushes the hiss as the changover from a sound mode occurs, but once changed over the hiss returns. Try it on an input not currently being used with the volume up.
I hope this is just a problem with this first batch! Otherwise it is a great receiver.
Paul
Oh, I tried out a 70es a few months ago and did NOT have any hiss to speak of.
Discussion Starter · #18 ·
Henry - thanks for the info. If this is not fixed it will kill this unit (and possibly the 2000 and 5000).
Another person at AC has confirmed that their AVD-S50ES has a hiss - but only at 100% volume and 1" from the speaker. That is pretty normal.
Discussion Starter · #20 ·
The 2000ES is a different chassis (at least it looks like it), so maybe it won't have the issue. The manual for the 3000 and 5000 is the same, the 5000 just has a few more features. They are most likely the same unit, the 5000 just having features 'turned on' (plus a few extra watts).
I tried a Monster line conditioner last night and it did not help with the hiss.
Tonight I will be hooking up my switchbox to A/B compare the unit to the Yamaha.
1 - 20 of 277 Posts
Status
