The main menu consists of - Level, Surround, Equalizer, Set-up, and Customize. Once you understand the lay-out of each of these you will be able to adjust or change any setting without having to turn on your television. To get used to this, while cycling through the different sections watch the display on the 4ES. It won't take long and you will know what to get into in order to change whatever you want. The individual EQ bands must be set using the onscreen display. You can cycle through/change the different "Banks 1-5" without having to turn on the televison. The person who designed that remote must have been some relative of Pavlov (Sp?). The rats trying to negotiate the maze in quest of the cheese!
As stated, you can change all speaker level settings.
