Status
Not open for further replies.
1 - 2 of 2 Posts
I've tried and tried and tried and tried but i cannot get it to work. I've tried it late at night. I've tried it in the morning. I've tried it with friends. I've tried it alone.
Is there anyone whou could please give me a simplier step by step idea of how to program this stupid fricken remote control so i can work my tv and dvd player with it. both are toshiba btw.
thanks
christy
ps I found the orange/brown alt button to do the numbers and it still won't work.
you have to get a pointy object and hold in the "use mode" button. Then press the AV green button beside and release both buttons.
The "use mode" light should say lit.
Then press the whatever function button you want to program, like Video1.
Then press the keys that are associated with the brown numbers. (it seems you don't have to press the alt key to get the numbers).
If it likes the code, the "use mode" button will flash 2 times.
And thats it. If it doesn't work, then either the code is wrong or the remote is not capable of controlling that component.
I've been trying to get the remote programmed for my expressvu receiver for days, but it won't. The sony phone tech support was no help either.
1 - 2 of 2 Posts
Status
