Status
Not open for further replies.
1 - 3 of 3 Posts
I currently own a Sony T60 and have a HD200 on order. I intend to connect both units to the same TV. Does anyone know if the two units use the same IR signal? I don't want two change the channel on my HD200 and have that interupt a record on the T60.
I have both. Basically, all you do is setup the remote code on the HD200 from "50" to "51", and then the code it sends will only effect the HD200, and not conflict with the Sony T60.
It's a simple setup in the HD200 under the "Advanced" I think. It's under "Remote Control Codes". You'll be fine, enjoy.
Discussion Starter · #3 ·
Does the change in remote code also require and change be made on the remote itself? Many of the older Sony products had a switch on the remote and on the device itself.
1 - 3 of 3 Posts
Status
