1 - 3 of 3 Posts
Banned
I'm currently test driving the KDL-60R550A, which is toward the lower end of the sony lineup and contains no "X-Reality PRO". It does, however contain "clear resolution enhancer".
I've looked through several sony sites and can't quite get a handle on whether or not people view this thing as worth it.
Most of the sites refer to "X-Reality PRO" being an 8 to 14 bit gradient upscaling, but those are from links about 2 years old. It's between this TV currently and the 802, and I'm having a hard time finding a reason to *not* stay with the R550A.
What is your experience with it?
Sony lineup chart, from the Amazon site:
In the LCd Forum there is a higher probability to find someone who ownes two Sony's, both with one of the engines (probably a Sony ho
Here is some X-Reality PRO info:
Q: What is Sony's commitment to high picture quality?
Motoe: Sony was particular about high picture quality from analog broadcast era. Since then we have been continuing with development and research. Sony first introduced our WEGA Engine for the CRT (Cathode-Ray Tube) televisions in 2003. Until then, the circuit consists of several blocks. To consolidate together in one small board, we named it the WEGA Engine.
CRT and LCD (Liquid Crystal Display) televisions have very different resolutions, especially when compared in terms of image noise. Improvements were made on the WEGA Engine and the birth of Sony’s BRAVIA line introduced the BRAVIA Engine. The BRAVIA Engine helped evolve this noise-reduction technology.
Q: How did BRAVIA Engine evolve into X-Reality?
Yamamoto : We developed algorithms (signal processing) for the picture quality circuit according to ever-changing trend and circumstances of TV technology and the market; such as the launch of digital broadcasting. We expanded BRAVIA Engine into BRAVIA Engine 2, and then BRAVIA Engine 3. We began to face challenges with noise-reduction technology in digital broadcast and gradation because of the panel’s limited specs.
From there, the picture quality circuit of BRAVIA Engine 3 evolved into “X-Reality PRO/X-Reality”. “The X-Reality/X-Reality PRO” engine incorporate Sony’s unique super-resolution technology. Other picture quality improvements include high definition, noise reduction, and dynamic color reproduction technology. Considering the support needed for today’s wide range of video content, improving picture quality is the strongest point; from native low-grade image quality to Full HD.
Q: What is the difference between X-Reality and X-Reality PRO?
Motoe: To restore resolution analyzing one image is single-frame method, while to restore resolution analyzing motion from multiple serial images is multi-frame analysis, which brings big difference in motion picture resolution. Furthermore, classifying input video signals to several thousand image patterns into database and processing super-resolution by referencing each pattern data enables us to restore images as similar to original image as possible. Thanks to the super-resolution optimized by database and multi-frame analysis, resolution restoration even for motion picture can be done with low noises.
“X-Reality PRO” is a combination of “X-Reality” and “XCA7”, a specialized picture engine. Noise reduction is improved by “X-Reality”, while “XCA7” improves super-resolution processing and gradation. XCA7 stands for “Extreme Creation Architecture”.
Q: What was addressed in the initial development phase of “X-Reality PRO”?
Motoe: “Beautiful video from low-grade content to High-definition”; under this concept efforts began to develop. Driving force was to help our customers enjoy more beautiful picture on Sony televisions sold globally.
Yamamoto: I still remember vividly that the first simulation image was so fascinating that our development team members exclaimed “I want to buy this television definitely”. All together we promised ourselves “I will develop what I can be content with”.
Q: Were there difficulties during development?
Yamamoto: It was a continuous struggle (laughs). Switching multiple databases and adopting various signals while maintaining the basic performance of super-resolution performance was quite difficult. We overcome difficulty through trial and error, utilizing the research result in high resolution technology including DRC. Through this effort, we were able to reach the outcome we dreamed from the beginning.
Q: Super-Resolution Optimized by Database & Multi-Frame Analysis is adopted by “X-Reality PRO”. Can you tell us more about super resolution optimized by multi-frame analysis?
Yamamoto: First, let me explain super-resolution optimized by multi-frame analysis. The conventional single-frame analysis was a technology to restore resolution. This information is calculated by referencing each surrounding pixel of a still image in a single frame. Of course, analyzing each pixel in a single frame shows improvement, it is still more efficient and more precise when being able to analyze pixels not only in one frame but also in multiple frames; we refer to this information on the time axis. By doing this, we can better understand the characteristics of the image.
Q: Other features of X-Reality PRO include a database of images. What kind of benefits does a database bring?
Yamamoto: We refer to the database when we restore the information obtained by analyzing multiple frames. It becomes possible to create more realistic and optimal super-resolution by process of analyzing wave form from video signals and increasing resolution of various patterns within picture characteristics, instead of simply interpolating pixels. This database has thousands of patterns that are available for High Definition (HD), Standard Definition (SD), SD up-conversion, IPTV and so forth. The database cannot be developed in a short period. It has evolved from DRC development and other technologies we accumulated from the past and can bring very high super-resolution quality.
Q: What technology do we use to maximize gradation?
Yamamoto: After improving the image quality based on the database, Super Bit Mapping for Video (SBM-V) applies a process to smoothen tone. Compensating for the tone of low bit rate video, SBM-V reduces banding noises that were visible in the tone of sky, for example, so that it looks as natural as possible. X-Reality PRO also has a process to maintain high gradation according to the panel resolution.
Q: Are there any other technologies behind X-Reality PRO?
Motoe: X-Reality PRO can control motion by the sub-pixel. The motion picture cannot be well reproduced on a pixel-by-pixel basis, as in many cases the picture moves by less than a pixel from one frame to the next. X-Reality PRO uses the sub-pixel control allowing better enhancement of the video resolution. Sub-pixel control may cause side effects such as adding unintentional noise without exact and appropriate control. We can control these effectively with X- Reality PRO.
Q: What is special about “X-Reality PRO”?
Motoe: It is possible to improve picture quality for digital satellite broadcasting and digital terrestrial broadcasting. For example, “X-Reality PRO” can reduce flickering and compression noise due to limited transmission bandwidth of digital broadcasting. This can improve the overall picture quality including line flickering and jagged noise even from conventional SD broadcasting, DVD and other SD content.
Yamamoto: X-Reality PRO also supports low-resolution images, which have increased in recent years, such as Internet Protocol Television (IPTV); YouTubeTM for example. Such content was intended to be viewed on a much smaller screen and the feeling of low-quality was noticed when moved to big-screen. X-Reality PRO improves the quality to reduce jagged noise.
Q: Is there a concrete scene where X-Reality PRO is utilized best?
Motoe: For example, a scene where the video camera moves slowly such as aerial scenes is one of typical scenes. With actually broadcast program, we don’t have absolute still image, but either the camera or subject is moving. It is possible to improve the total picture quality by removing outstanding noises especially in slowly moving scene. Experience the beautiful imagery of “X-Reality PRO” in current BRAVIA line.
Right: Hisafumi Motoe
Deputy General Manager (back End System)
Home Entertainment Business Group
Sony Corporation
Left: Yosuke Yamamoto
Project Leader of XCA7 Development
Sony Corporation
Banned
Discussion Starter · #3 ·
Originally Posted by 8mile13  /t/1472542/sony-technology-101-is-x-reality-pro-worth-it/0_100#post_23310853
Yes, but it's here where the probability is best that I'll find the highest end theory guys who've tested and beaten up the concept first hand. Especially them XBR folks. Nothing pleases them.
1 - 3 of 3 Posts
