I recently purchased a WD1200AB hard drive and followed the instructions posted at http://www.blindsquirrel.org/UTV/default.htm to upgrade the hard drive in my Sony SAT-W60 UltimateTV receiver. However, I ran into a problem. After replacing the hard drive and powering the unit back up, the UTV came up with the screen saying that it would need to check for updates. It then dialed the toll free number and then said that it would reconnect. It went through a series of messages beginning with dialing a local number, then waiting to connect, and finally connecting. This is where it stopped. It just sits on the "Connecting..." message and doesn't proceed. I have tried to power off the unit and power it back on, but it just starts with trying to connect to the local number and then hangs at "Connecting..." again. I have called the local number with my telephone, and a modem does indeed answer. Does anyone have any suggestions?
Thank you,
Yogi
Thank you,
Yogi
