This is my first projector (thanks Donnie) and I have a long list of questions. They may seem kind of dumb but I will ask anyway. Thanks.
-Does anyone have a manual on this one?
-I did a basic setup and the screen size is around 68 inches. Is there any way to make the picture larger (100"ish)? Would it need more that a 13 foot throw distance?
-There is a weird rainbow that is cast right under the picture that seems to be reflecting off of some sort of internal fluid (coolant?). The rainbow even ripples whenever I bump the projector. What could this be and is it bad?
-I don't hear any fans, but it did not get hot after an hour of running. Does this sound good.
-Can I harm the crts if I crank up the picture brightness, and watch widescreen movies?
-Could I connect a DVD with a component output (3 cables) into a RGB input (5 cables)?
I think that these are the main questions for now. Obviously I am a greenhorn to this. Thanks again
Dcmicrobe
Dcmicrobe
