Status
Not open for further replies.
1 - 2 of 2 Posts
The blue line for focusing on my unit was blurry and thich in the bigning. Than I moved and took my project with me as soon as I hooked at the new place, the blue light would not come on. I tried the focus pin and the light came on but will not focus into a cross (for focusing). Is the Blue CRT gone or there is something else.
Had a similar problem with my 1041 ( blurry and unfocused blue, very dark image ). Then I got a tip about the G2 settings and that solved it. I don't know if you have the same problem.
So try the G2 knobs for the blue tube. There you can adjust the focus and the light, but be careful so you don't burn anything.
The G2 knobs are situated above ( closer to the tubes ) the registration pins ( on the 1041 ) there are thee black and three white. Try them!
:D
Moi
1 - 2 of 2 Posts
Status
