Originally Posted by darinp2 /forum/post/20887845
Thanks Kraine. From that link it looks like the lamp is the same $1000 one that Sony used in the VW100:
http://store.sony.com/webapp/wcs/sto...Number=LMPH400
--Darin
Originally Posted by mark haflich /forum/post/20888169
It is fairly obvious that the new projector uses a Xenon lamp. There are certain advantages to using a Xenon lamp if one watches films and commensurate with a top of the line machine from a company, they elected to use a Xenon lamp.
Originally Posted by mark haflich /forum/post/20888391
This subject has been beaten to death previously. And there is much more to how your eyes see a picture than just how a meter measons the color points For example, three DLP chip machines have a more satisfying solid image than one chip DLP machines. Much less filtering has to be used with a Xenon bulb than with a UHP bulb. Light output considerations aside, because filtering must necessarily reduce light output when the limit is reached for one color, I suspect that there are other picture quality considerations which come into play. I leave it to others todiscuss them where they have been discussed in various threads.
Originally Posted by Lawguy ![]() I'm not sure why any of this would be a mystery. How colors are defined by measurements is accepted scientific fact... |
