Status
Not open for further replies.
1 - 1 of 1 Posts
I have recently been having problems with my sony VPL X600 projector.....a yellow band has started appearing at the top of the projected image, on closer inspection inside the unit I have found that the blue lcd slide has started to break down causing the yellow band on the image.
Is there any way I can get this LCD slide fixed or do I have to buy a new slide,I have heard that these slides are not cheap to replace and many people end up buying new projectors as this is not cost effective.Unfortunately I haven't got the funds to do this, I am also trying to find another broken unit that I can maybe take the slides out of thus getting my projector working again .
Any help on this matter would be really appreciated
1 - 1 of 1 Posts
Status
