A couple weeks ago I left the room after a moive and came back about 2 minutes later. I could see a bit of smoke in front of the lens / light beam. I also started to smell burning electronics. The projector was still functioning. I shut it down and let the smoke clear. The next day I started it up again. No smoke but still a burning electronics smell. I decided to unmount it and send it to sony. But then I thought better of it. I unboxed it and set it on a table to project rather than hung from ceiling. There was less smell and after more hours of use pretty much no smell. So I rehung it. The stronger smell returned.
I've seen no visible smoke since the original instance that occured when I was out of the room. The picture still looks ok. The lamp has about 1750 hours on it. If I recall correctly the expected life is 1500 to 2000 hours. So I am probably faced with about a $750 cost to replace the lamp soon.
Might the old lamp be the source of the smell?
If I'm not sure a $750 lamp is going to fix the problem with the smell and give me another 1500 hours of viewing, perhaps I should consider just purchasing a new VW10. I'd sure hate too spend $750 on a lamp and find I've got other repairs that need to be done too!
The VX10 uses about 1/2 the power of the VX100 and has 24p which would be nice.
Has anyone else encountered the brief smoke and then lasting smell symptoms with the VX100?
If I was sure a new lamp would fix the smell problem I'd just live with the VX100 for another lamp life...
