Any other comments on the X85K? I'm looking at the 75" as an option should it go on clearance for a great deal. This TV checks a lot of boxes for me. I'm not 100% sold on mini led as I've read most suffer from bad blooming (especially off center). I don't believe the X85K suffers from blooming as it doesn't have mini led (correct me if I'm wrong).
Does anyone else own the X85? If so how is it? I know it's a VA panel but when I view it in store the viewing angles look pretty decent to me. I need decent viewing angles for my setup and current use a 5ish year old LG IPS panel (65").
The X85K was my best option to get an 85" set (and once you're used to it you wonder why anyone would get anything smaller) after the place selling the equivalent Samsung confirmed all their panels had blotchy blacks. I had the X85J for a few months before I asked for a replacement due to similar panel issues and actually got an X85K with a completely uniform panel as a replacement. Got it off Sony's Australian eBay account, so I can recommend their service.
In a dark room, the black levels aren't great compared to a set with local dimming or OLED, obviously, but with the brightness at 0/Min it's a lot better than a projection screen at a good cinema. If there was a way to dial down the backlight a notch or two more, it'd be pretty amazing, as even at brightness 0 the highlights are still crazy in a dark room. I was beginning to think HDR was overhyped but with this much brightness on tap it really is something to see. I think in terms of PQ, it's about as good as you're going to get for conventional non-local-dimming LCD.
Featurewise, I can't imagine anything better for the money. VRR, eARC, Dolby Vision, everything you could want from a modern TV. With Gamer Mode enabled, there's no trailing or smearing and lag isn't perceptible. It's great for actual games.
Only minor drawback is a bit of noise when changing sources through eARC, but there are always claims this will be fixed with an update. Same problem on X85J was a little reduced - but not eliminated - with an update. Also, with a set this size, the VA viewing angle limitations are easily apparent, but obviously not a problem when you're in the right spot.
Bear in mind my last TV was a 46" Z4500 from 2008, which I was always happy with it for what it was and kept for 14 years, and this is a massive overall upgrade even though that was an IPS panel. Keep your expectations in check with the black levels (they're still good for this type of set) and you should be very happy with this much TV for the price.
Edited to add: Viewing angles
are a bit of an issue, but not in my setup. I once watched it from the Other Sofa (about 30° off-axis) when I had guests and it was still very watchable but obviously a little compromised. I recommend a wall-mount that allows vertical tilt to point the screen directly at you.
