Simple Questions from a newbie:
Anyone using a Monster power strip/unit for surge protection/cleaner power thus better picture?
Anyone get a ISF Tech to tweak OTB? Was it worth it?
Anyone decide on a DVD Player after trying several? is it worth going DVI out? If not DVI out, component w/ standard prog. scan?
Does it throw much heat? i'm building in, should i worry about an exhaust fan?
I plan to go OTA antenna, Cable HD and try a dish...looking for HD options,I understand that some Cables are better than others depending on who you have and where you live, but...has anyone gone w/ voom? has anyone tried the attic antenna vs. a rooftop antenna? it's fri$%ing cold up here in Maine and i'd hate to climb on the roof this week if i dont' have to. Any antenna advice would be appreciated.
Anybody get a GVVIII w/ a build date after 1.1.04 that had major trouble?
anyone have a definitive solution for 1024X768 PC use? powerstrip results?
Come one,come all....answer one, answer all, anyone? anyone??
Thanks in advance.
Thanks in advance.
