Good question?
To turn on with the remote top green button you do need a line of sight to the bottom center of the screen, around where the Sony logo is as that is a normal Infrared command, ... but ... once turned on you do not need a line of sight as the remote uses Bluetooth for all the other function changes such as input, volume, channel, etc, it is a nice remote but does not have a backlight keypad like the 2020 ZH8.
The manual on/off switch + volume is located around the back of the TV on the Left-hand side with the TV facing you around 2" in, a small 3 button affair.
I decided on mine to mount it 30" high off the ground on a movable TV presentation stand as I can then move the setup around the room, that gave me the clearance I needed to site my center speaker on top of my sub as I could not find a decent center speaker stand for that height!
I'm using Monitor Audio Gold GX300 speakers and a Gold GXC350 center speaker, with Gold GXW 15 subwoofer, with Gold surrounds, connected to a Yamaha RX-A3070 AV Amp,
Gold GX
Don't forget you can use your Sony TV as a center speaker as it does sound good!
And you could just walk up to your TV, if the center speaker was blocking the Infrared sensor, and just point it behind the center speaker to turn it on/off as once on you no longer need any line of sight as Bluetooth remote!
A picture of my rough set up at the moment!
Good luck, it is a lovely TV!
