Delete.
They look about the same as the Z9F to my eye.I have a Z9f which I think has fair viewing angles for an lcd how does the Z9g compare? Have they improved or pretty much stayed the same?
ThanksThey look about the same as the Z9F to my eye.
Z9J Zones are not confirmed nor is brightnessGuys, finally got around to testing my series X with a 2.1 cable, and it looks like hdmi port 4 is dead... I have my Denon on hdmi 3, and UB9000 on hdmi 2, which only leaves me hdmi 1 for my series X. This led to the discovery that port 1, while it works somewhat, is also messed up. On port 1 I can't get hdr no matter what( tried 5 different cables on 4 devices) and there is also artifacting that looks like macro blocking you would see in a heavily compressed stream.
I'm going to be returning it guys, I won't take a Z8H or Z9J as replacement due to the huge downgrade in nits and zones.
I'll probably take a shot at the 85" Samsung QN90A.
Man I feel you. Mine has been awesome except the rebooting issue every time I turn the tv on which is starting to drive us nuts! I just don’t think Sony has new Z9G replacements and the only other tv I would even want is the A90J.Guys, finally got around to testing my series X with a 2.1 cable, and it looks like hdmi port 4 is dead... I have my Denon on hdmi 3, and UB9000 on hdmi 2, which only leaves me hdmi 1 for my series X. This led to the discovery that port 1, while it works somewhat, is also messed up. On port 1 I can't get hdr no matter what( tried 5 different cables on 4 devices) and there is also artifacting that looks like macro blocking you would see in a heavily compressed stream.
I did, I just don't get any signal.Did you try playing with the HDMI format menu on the TV?
From this review:
"The HDMI4 port has a special menu that can be used to activate "enhanced mode" (for 8K or 4K120)."
If I switch the Xbox over to hdmi 2 where the ub9000 was, it works just fine.You can rule out physical damage to the ports by temporarily swapping the devices that are currently working on HDMI 2/3 over to these malfunctioning ports. Does your UB9000 and Denon work on HDMI ports 1 and 4? If so, then it sounds like some issue specific to the Xbox. In that case, does Xbox work correctly on HDMI 2 and 3 (minus the HDMI 2.1 features)?
Is your TV coming with warranty ? Did you ask Sony or the store about it ?If I switch the Xbox over to hdmi 2 where the ub9000 was, it works just fine.
I have Emailed the store about returning it. I know Sony will want to give me a Z8H... no.Is your TV coming with warranty ? Did you ask Sony or the store about it ?
Once you make sure HDMI 4 is set to enhanced 8K, plug in the Xbox and go into the settings where you also have to enable all the 4K/120 features. Also make sure HDR is set properly on your Xbox. It may be an issue with your series x more so than the TV. HDMI 1 issue your having is weird though. It sure about it.I have Emailed the store about returning it. I know Sony will want to give me a Z8H... no.
I've actually Pre-ordered an 85" QN90A as a replacement.
I have. Simply moving the Xbox over to port 2 (also tested 3) causes everything to work as it should, I just can't get any signal on port 4 at all. Port 1 I'm going to see if I can follow up with Sony when they get this back, at wherever defective TV's go. I'm really curious as to what the issue is with port 1.Once you make sure HDMI 4 is set to enhanced 8K, plug in the Xbox and go into the settings where you also have to enable all the 4K/120 features. Also make sure HDR is set properly on your Xbox. It may be an issue with your series x more so than the TV. HDMI 1 issue your having is weird though. It sure about it.
It's from the same source that disassembled Z9G and Z8H. Pretty trustworthy in my book.Z9J Zones are not confirmed nor is brightness
Anything from China, take with a grain of salt,
until the well know reviewers like Vincent and others on here get them in for testing. I’m gonna treat anything new as unknown!
Although this is a nice find, I would discourage anyone from paying 12K for this television.Amazon suddenly has one in stock, ships from and sold by Amazon. I would usually not post something like this here, but I figured since it's a rare, discontinued model, someone might like a chance at it.
