Status
Not open for further replies.
1 - 9 of 9 Posts
After tweaking my system for several months, I am finally thinking of room treatment. I noticed that my left speaker (has a built-in powered sub) has peaks at low frequencies and has a very different bass response compared to the identical right-speaker though the gain for the built-in sub is turned way down low. It is about 2' away from the back wall and 2' away from the nearest point in the side wall and 4' away from the farthest point on the side wall. The side wall curves at the fire-place and hence this problem.
What kind of material should I use for sound absorption/diffusion just behind the left speaker for the rear wall ? I guess a 5'x5' foam may work well as part of it can hide behind a 55" TV. Is there any special kind of foam that can be covered with GOM or similar type of material ? Please note that this is a temporary solution (10 months) in a town home. Please include links on products and also places to shop for. How much would it cost for a 5'x5' absorption/diffusion material.
-Jai
Try this:
http://www.avscience.com/acousticpannel.htm
I used it at all points of first reflection. For really low bass, however, you need some "bass traps". Any questions, let me know.
BTW, I did not use the plywood on the back of the "soundboard." Andrew calls it sof-board. It did not need the plywood. I like this best because you do not need to build a frame. Just overlap the foam and use "liquid nails" to hold it over the soundboard. Of course you then attach the fabric over the foam.
I found the soundboard at a local lumberyard. Lowe's and Home Depot did not have it. It is called "Hushboard" and I think it is made by Georgia-Pacific.
Regards, Tom B.
Discussion Starter · #5 ·
Thanks Tom and Clark. I would consider treatments for first reflection when I have a dedicated theater room, but for now, it looks like what I need the most are "bass traps". Can you elaborate a little more on bass traps. Any links to easy DIY projects to build bass traps would be great. If DIY is too complicated, where is the best place to shop for "bass traps" ?
-Jai
I'm using theater-shield (Black fiberglass batting with an acostically transparent black cloth backing on one side) with GOM fabric.
Theatre-shield is $225.00 for a 100' long 4' wide roll.
will find out how it works in a few days...
1 - 9 of 9 Posts
Status
