1 - 4 of 4 Posts
[cross posting in soundbar section]
As of now I cannot run wires thru the room for rear speakers and cannot mount or provide power for wireless rear speakers.
So i have left with 2 options for my home theatre system setup.
1. get a soundbar with subwoofer (like sony htc150 or 350)
2. Or get a htib like onkyo HT-S3300 or BDV-570 and just use the front 3 speakers & subwoofer
Which is a better approach and which will provide the better over all experience and any suggestion or recommendation for which one to get in the category? My budget is around $400-$500.
thanks
Get a 5.1 Yamaha YSP unit which creates a complete surround system !!
3.1 is 3.1
As to budget, look on Craigslist, eBay, etc. for a pre-owned unit. Much more bang for the buck!
Check http://usa.yamaha.com/products/audio-visual/digital-sound-projector/ for the latest products. Your budget is small so you must find the least expensive that does 5.1 and has sufficient HDMI switching to handle your needs. They also have an archive section to check some older units you micht find in the pre-owned market.
they all work well within the limits of their feature sets!
1 - 4 of 4 Posts
