1 - 7 of 7 Posts
· Registered
I use SB live pro, but any cheap sound card from behringer would do the job equally well.
· Registered
I'd also suggest looking at this USB DAC as it's gotten pretty great reviews, especially at its price:
http://us.hifimediy.com/index.php?route=product/product&product_id=50
Here's the thread on diyaudio.com:
http://www.diyaudio.com/forums/digital-line-level/219140-hifimediy-es9023-te7022-24-96-usb-dac.html
I just received one a few days ago and so far I'm absolutely loving it. It's USB and TINY so once you're done using it with the laptop you can always shift it to a PC or keep the laptop near the audio system and use it as a dedicated music server offering up bit-perfect lossless audio up to 24-bit/96kHz. Just an idea.
· Banned
Originally Posted by ozziedog  /t/1470951/sound-card-advice#post_23279122
Yes it does. How would I make that work?
If you have a headphone output jack and a mic input jack you have an internal sound card, you use it like any sound card.
  • Like
Reactions: MemX
1 - 7 of 7 Posts
