Try a multi-input card like one in the Delta 410 Series.
That way you would connect all of your sources at the same time- no switching involved. Just setup the mixer correctly and yu should be set.
I use the AP24/96, but only have to switch for DTS pass-thru only. BTW, I use myHD's spdif out, have you considered that?
