Sound Card with Digital Out (to hook to Onkyo 875)
844 Views 3 Replies 2 Participants Last post by  solrad
I am looking for a sound card with at least 2 digital outputs, one of which must be optical. The second can be either optical or coaxial.
My goal is to run digital sound output from my computer to two separate A/V receivers: one Onkyo TX-SR875 and an older Sherwood-Newcastle in the next room.
Any suggestions?.....
1 - 4 of 4 Posts
Scored big time with Oxygen HD chip based Bluegears B-Enspirer DTS encoding 24 bit 192kHz cards, about $45 on the eecky bay. Fabulous sound, even though they use optical out. They replaced the venerable 2 channel PCM coax 44kHz TB Santa Cruz cards on the HTPC and work rig upstairs.
The elusive X-Meridian is another story.
Of course read up, but you will come back to C-Media cards.
At work i use a lesser X-plosion with a Yamaha DP-U50 96kHz PCM coax accepting processor, and Swans amplified speakers, very happy with Bluefm Korean ambient station.
In my wife and coworker's office i had to use a workaround with her old laptop with a PCMCIA USB2 adapter - E-Mu 0202 - Parasound Zamp v.2 - Energy E 2.1s all from the eecky bay for funny money. Needless to say her 192KHz setup is a lot better sounding, but she is making a third baby and needs all the relaxation she can get now
Winamp both computers of course.
And for the other room snag an Optiplex P4 tower with half a gig memory for about $100 off ebay, then put the card on it, fewer trips to the other room.
See less See more
Hmmm, the Auzentech X-Meridian seems like it would be perfect. Since I could get one digital out on the main card and the second digital out on an add-on X-Tension DIN card.
Unfortunately, I cannot find the X-Meridian for sale anywhere. And the Auzentech site says they are not making them anymore. *sad face*
The B-Enspirer looks great, but as far as I can tell it only has a single digital output?
Thanks for the suggestions, by the way!
The goal is to have the same sound playing in both rooms simultaneously, so this option will not work....
1 - 4 of 4 Posts
