Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
Originally Posted by jmhc /forum/post/18115367
Hello there:
Does anybody know if I can use egg cartons as a cheap sustitute for sound diffusors. From 1 to 5 how wolud you qualify the diffusion performance??
Thank you.
Originally Posted by Weasel9992 /forum/post/18115476
No, you can't. I'd rate them at 0, no kidding. Even CD's, records or books on a bookshelf would work much better, and that's not saying much.
Frank
Originally Posted by jmhc /forum/post/18117111
Thank you Frank for the reply, I considered the egg cartons because I saw on the internet sound diffusor panels with a very similar shape.
Anyway, if not much trouble, can you tell me what cause the poor diffusing performance, if it is in the shape or it is in the material that they are made of.
Regards.
Originally Posted by Weasel9992 /forum/post/18117255
Well, both really. They're too soft, and given their density they absorb along a very narrow bandwidth...if you have an 800Hz problem in your room they're perfect.The other issue is the fact the fact that you'll always have a repeating patter no matter how you orient them. That's real bad when it comes to diffusion.![]()
Frank
Originally Posted by Ethan Winer /forum/post/18117513
Besides the spot-on advice you got from Frank, this video demonstrates a lot of what you are asking:
All About Diffusion
--Ethan
Originally Posted by JOHNnDENVER /forum/post/18118096
Microfiber furniture...![]()
Really he is not saying to use books on a bookshelf.
Even relatively simple bass traps should be at least in the relhm of a proper design.
Can you tell us what you are really attempting to accomplish here?
Originally Posted by gryhnd /forum/post/18120950
Wouldn't happen to be this, would it:
http://www.mioculture.com/store/pc/v...sp?idproduct=9
I bookmarked those a couple years ago. Never ended up using them though...
Originally Posted by Weasel9992 /forum/post/18121946
You're usually better off concentrating on absorption as a first step at least, then once the room is more controlled you can take a longer look at diffusion.
Frank
Originally Posted by jmhc /forum/post/18122077
Frank, I'm planning to cover the 4 walls of the room with 1/2 inch couch foam and heavey cloth, will that be a good starting point??.
Originally Posted by Weasel9992 /forum/post/18122234
NO. Don't do that. You'll over absorb the highs and do absolutely nothing for the lows, so the room will be dry and boomy. Not good.
Can you post a diagram of the room so we can take a look at what you have to work with?
Frank
Frank
Frank
Originally Posted by Weasel9992 /forum/post/18128787
I'd start simply since it sounds like you want a more lively environment: bass trapping in the front corners, 2" panels at the reflection points and thicker, 6" bass traps (2) on the back wall. If you can't fit 6" traps, go with 4". You can always add more absorption if you think you need it. That's just a starting place.
Frank
Originally Posted by jmhc /forum/post/18131960
Frank what about the floor, it is 100% reflective, do you think it will be good if I cover the entire floor with a carpet??
Originally Posted by Weasel9992 /forum/post/18134283
Eh..not the whole floor, unless wall-to-wall carpet is what you want from an aesthetic standpoint. A 5'x8' area rug or two and some experimentation in terms of placement will do nicely.
Frank
