I am about to have a new house built that will include a dedicated theater. Although I should be concerned about sound getting into the theater my main concern is sound getting out.
Roof decking will be 7/16th radiant barrier. Roofing will be shingles over 16lb underlayment. R-40 blown attic insulation. Walls have a minimum of 7/16th OSB behind a stone veneer. Sheetrock is 1/2" at walls, 5/8" on ceiling.
Will I need additional sound proofing in the theater room so that I won't disturb the neighbors? The closest house will be 20ft away?
Many thanks
Many thanks
