Status
Not open for further replies.
1 - 20 of 30 Posts
Hi.
This thread concerns only Delta 410, 1010LT and 1010. I don't know if the problem exists with the Revo.
I have now a HTPC based on XP (WinMe before), so I give a trial to the Maudio 5.10.00.0031 wdm driver (I have a delta 1010). I have encoded a small 3 second ac3 file with simultaneously :
1000 Hz -20dBFS on FL FR C SL SR
80 Hz -20dBFS on LFE
So all channel have the SAME level. Dialogue normalization is encoded at -31dB (thus no attenuation should be done by the decoder during the decoding process).
The bass managment setup is given in the snapshot "Bass Management 5.10.00.0031.png" :
- no filtering
- no reroute
==> LFE +10dB ON
Discussion Starter · #9 ·
I tested v5.10.00.0029 driver yesterday.
I recommend this new version because some bugs have been solved (see below).
First, here is the peak meters view with bass managment OFF.
==> All is CORRECT. You can see each -20 dBFS signals on each channel.
So now we know that the audio levels encoded on the ac3 are correct.
Emmanuel
Discussion Starter · #12 ·
Center reroute :
Some obvious math : if FL, FR and C play A level, each give 20 log A decibels.
When C is reroute, FL and FR must play A + A/2
X = 20 log (A + A/2) = 20 log (3A / 2) = 20 log A + 20 log 3/2 = 20 log A + 3.52dB
In the ac3, 20 log A = -20 dBFS. Thus FL and FR should play at -16.48 dB.
It is difficult to see exactly the FL and FR levels on the peak meters, but it seems more closed to -15dB than -16.48 dB
Premium Member
These are great tests! I experience the same type of thing on my system. It is a shame because I don't have a center channel and want to route LFE to the mains, but getting the bass right is basically impossible.
Originally posted by Pultzar
Can anybody confirm if these problems also exist with the Revo?
Yes it does! Just received a call from M Audio to discuss this problem (because they did receive all 7 emails as stated above).
While he's at it, the new programmer might want to take a look at the Sonica Theater's behaviour under similar circumstances, something funny going on with that too, at least in 6.1 and 7.1 mode switching between bass mgmt on and off.
Discussion Starter · #20 ·
Filtering Test
Encoded C level : 30Hz at -20 dBFS
The filters implemented in the Delta Bass Managment are -12 dB/oct.
- With Crossover freq. set to 60 Hz the signal should be attenuated by 12dB (30 Hz is one octave below 60 Hz) and the C level should be -32 dBFS
- With Crossover freq. set to 120 Hz the signal should be attenuated by 24dB (30 Hz is two octaves below 120 Hz) and the C level should be -44 dBFS.
These two values are theorical asymptotic values. Real values are a little smaller.
The C levels after filtering in both cases seem "correct" because they are closed to -33 and -48dB.
1 - 20 of 30 Posts
Status
