Hi,
couple questions,I have done reading up on using sound level meter for calibrating my speakers and just need to tick the box if this unit will do the job,link http://www.ebay.com....984.m1438.l2649 ..
Also as I have ceiling speakers as my surrounds would I put the meter mic straight up in my seating position or leave it at the 45 deg angle facing the fronts,from what I have been reading there are two alternatives,angle forward or straight up.
I am also after a calibration dvd ( blu ray) one that has test tones etc on it,I have searched all my local shops to no avail and can not seem to find one which will suit region B,any suggestions on where I could locate one,my blu ray player is not region free.
One other question will I have to calibrate the meter when it arrives.
Thank you.
Thank you.
