I finally fixed a very frustrating problem this evening and I thought I'd post for the benefit of anyone else with this kind of a problem.
Specs:
AMD 1.2GHz (266)
ABIT KT7A MB
256Meg PC133 Kingston ValueRAM
30Gig IBM 7200rpm HD
Pioneer DVD116 (tray)
Zoltrix Nightingale Pro
ATI Radeon LE
NEC LT150
The system is configured to output audio via the SPDIF output to my receiver, a Denon AVR3300.
The problem I was having was "pops" in the audio stream which seemed to actually be very brief dropouts during which the receiver would lose lock. During DTS tracks the pops were replaced with very loud chirps that were so loud I thought they might damage my gear. Occasionally I could observe the "auto" indicator on my receiver go out. This problem persisted over two different sound cards (the Zoltrix and a Creative Live Value), both types of SPDIF output (coax and optical), with and without IRQ sharing on the soundcard, several different driver versions, and also occurred in both Win98SE and WinME.
Finally tonight the problem was fixed by *underclocking* my processor to 1GHz w/100MHz FSB. My personal opinion is that the problem was electrical in nature as opposed to functional, but I haven't delved much further on the problem yet and I'm not likely to for some time. I can run the system at 1.2GHz w/100MHz FSB to see if that works, as well as 1GHz w/133MHz FSB. I can also probably try some better memory to see if that was causing problems.
Anyway, I just thought I'd post to give people with problems some hope. And while I'd like to get to the root of my problem and fix it, my machine has more than enough horsepower for playing DVDs and I couldn't be happier that I get clean 5.1 sound now. Hope this helps someone out.
Specs:
AMD 1.2GHz (266)
ABIT KT7A MB
ATI Radeon LE
NEC LT150
