Status
Not open for further replies.
1 - 2 of 2 Posts
I have two 4504s, Den and Living Room. If I stream a show from Den to Living Room, I only have left channel sound. If I stream the show to DVArchive, same thing. If I play that show on Den, I have both channels. If I stream shows from Living Room to Den or DVArchive, I have both channels.
Something about the way Den is sending shows is only sending the left channel. Any ideas?
This is odd...
I've been thinking about trying a test to find out if the MPEG stream is a file copy stream or if there is some demuxing that happens before the data is streamed.
Few questions about your tesing:
Playing back on the PC either streamed or local on the PC give you left channel?
The Livingroom Replay has both channels if you play the replay?
Aren't Den and living room the same thing?
How are these replay connected? I ask because if either replay goes through a receiver or tv those devices could be configued incorrectly. I'd also make sure you don't have some "simulated stereo" mode enabled.
The mpeg audio shouldn't be able to have stereo and left only without cable poblems or some receiver setting.
1 - 2 of 2 Posts
Status
