Sound proof panels
463 Views 5 Replies 4 Participants Last post by  Brian Ravnaas
Has anyone ever poured precast concrete wall panels to sound proof a home theater? say 4'x8' x 1" thick. I work with concrete, you Could pour on basement floor 7 tilt up into place What do you think?
Status
Not open for further replies.
1 - 6 of 6 Posts
HELP!! Has anyone ever poured precast concrete wall panels to sound proof a home theater? Say 4'x8' x1" thick I could pour them on basement floor 7 tilt up into place. they would weight about 400lbs each. I don't think sound would get through something like that? I would even use this for ceiling panels. they would rest on top of the wall panels?
HELP!! Has anyone ever poured precast concrete wall panels to sound proof a home theater? Say 4'xxi8' x1" thick I could pour them on basement floor 7 tilt up into place. they would weight about 400lbs each. I don't think sound would get through something like that? I would even use this for ceiling panels. they would rest on top of the wall panels?
"HELP!!"? Is this some sort of holiday concrete emergency? :)
Yes, sound would still get through this. Concrete has about 3x the density of drywall, so it is theoretically better mass-wise. But it would be a real pain to work with compared to drywall.
- Terry
You wouldn't get me sitting under a home poured 1 inch thick slab of concrete.
But I guess you are talking about a properly supported slab. I recall seeing a wood frame house being built that had poured concrete floors. As I recall they had exterior grade plywood as the immediate subfloor. Then they ran PT lumber around the perimeter of every room and hall, put down a plastic sheet then poured the 1 1/2 inches using the perimeter frame as a guide. The walls had double thickness of lumber on the bottom to get a bottom plate above floor level.
It was all about quieting the floor. I imagine the floor joist system was sized for the weight.
hi Bob E, and happy holidays AVS,
1" of concrete would have the mass of perhaps 5-6 sheets of 5/8" drywall. So that's a good start, no question. However, it has insanely low internal damping (so it's quite resonant) and it conducts sound very well (which is why concrete is often a flanking noise liability).
If used in a decoupled wall arrangement, like staggered studs or double studs, and IF THE LOCAL BUILDING OFFICE APPROVES, you could attain really nice results. Use as a single panel (no air space, no insulation) or on a conventional wall where the panels are bolted directly to the wall, performance won't be as good.
But, on a decoupled assembly, like a double stud wall, all that mass will go a long, long ways.
on floors concrete (and gypsum concrete) are generally impact noise (footstep noise, something dropped on the floor, a sliding chair) liabilities. throw in tile and hardwood, and those hard surfaces are responsible for probably 95% of the impact noise reducing products around... but in combination with carpet the mass can be a good thing (carpet takes out the "ping" potential)
Brian
See less See more
1 - 6 of 6 Posts
Status
