Just did a Google search of free recording software . The 1st link listed got me nowhere, but the 2nd I found KRISTAL Audio Engine , which is supposed to be bery good...
I also refind the search to "free recording software" & it looks like I got much more pertinent (belonging or related to the subject or matter in hand) results.
PS - another link mentioned Quartz Audio Master & Audacity .
PSS - finding all sorts of stuff, e.g. with BumpUp.exe "BumpUp.exe quadruples the size of a wave file, making it sound four times lower. This allows you to hear the super high frequency content in your music and work with it. When you are done filtering it you can then run BumpDown to return your masterpiece to its original speed. Desnap eliminates loud unwanted clicks from digital music without sacrificing any brilliance. This is not a filter. It scans wave files for snap events and fixes them."
