I'm new here and, typically, starting off in a weird way. I suppose you folks probably never look at equipment of the type I need right now, but I want to ask for your advice.
I spend about an hour to an hour-and-a-half on the treadmill every day. I just got a Phillips 17" HDTV and mounted it with a DVD player on a tall table with a small footprint just ahead of the treadmill so that I could do the couch potato thing while running. This treadmill is a very good, quiet system. But it is still loud enough (especially with my footfall sounds on the belt) to make the sound system that's built into the TV quite marginal.
It's obvious that I don't have to have a very refined sound system if I'm only going to use this system when I'm running, but I'd rather not buy a real dog. I probably won't use the TV at all except when I'm running. Should I get a boom box for this application, or does anyone know of a different type of form factor that would serve the purpose?
I guess I would pipe the sound from the DVD player to the amp/speakers. It could be coax digital, optical digital, or a plain old left/right RCA pair.
Ernie
Ernie
