1 - 2 of 2 Posts
I just bought the VSB200 and it sounds great with my new tv. But I just tried to play a blu-ray and I can only get the tv channels playing through the soundbar even though the movie is playing. What am I doing wrong?? Please someone help me! Thank you!
Is the Blu-Ray connected to television of soundbar?
What are the audio settings for Blu-Ray?
The VSB200 can only decode PCM, so if your Blu-Ray is set for bitstream, you will get nothing.
Also, with some (most?) blu-ray players, you have to tell it where to send audio out. For instance, if your Blu-Ray was connected via HDMI to your TV and had the sound going to the TV and now you have the player connected to the soundbar via optical, you may be required to tell the player to send the sound to optical out using PCM.
1 - 2 of 2 Posts
