Status
Not open for further replies.
1 - 6 of 6 Posts
I've been having lots of problems with my WD7UY (see other thread).
Out of curiousity, is it normal for the plasma to make a CLICK-DA-CLICK (double click) sound when you turn it on?
This seemed weird since all other TV's I've owned just single CLICK on, but maybe it's a plasma thing...
Normal?!
Thanks...
My 42" consumer panny plasma makes 2 clicks when I turn it on, and 2 clicks when I turn it off. I've accepted it as normal. It does not, however, cook me dinners, which I find extremely unhelpful. An e-mail to Panasonic is forthcoming.
Discussion Starter · #5 ·
Hmmmm... mine only makes 1 click when it turns off. That must be the problem.
I'd guess the clicks are some sort of power supply relay turning on in two stages. Glad to know it's a normal noise... even though EVERYTHING else in my house just needs a single click.
1 - 6 of 6 Posts
Status
