Hey, I use multiple montiors on my PC.
Therefore, I'm looking for a good quality soundbar that can go under my monitors.
I currently have the Samsung HW-M450ZA: https://www.samsung.com/us/televisi...ch-soundbar-w--wireless-subwoofer-hw-m450-za/
Problem is, there are no tweeters only mids & everything sounds deeper than it should.
I used to have the logitech z4 & would set them down so they wouldn't interfere with my multiple displays: https://techgage.com/article/logitech_z-4_21_speakers/
The highs definitely sounds more accurate than on the samsung but the wattage is very low (8.5W rms/speaker). This caused the sound to distort after about 10 feet away (i sometimes use speakers to listen to music while in my room but not at my desktop).
So I'm looking for a solution where the sound won't distort for at least 20 feet & I still get accurate sound (including highs). And of course it can go under my multiple displays
I'm currently looking at the razer leviathan: https://www.razer.com/ca-en/gaming-audio/razer-leviathan
& the creative sound blasterx katana: https://us.creative.com/p/speakers/sound-blasterx-katana
Which one of the two would you recommend? Or is there something out there that is better for my needs?
