1 - 3 of 3 Posts
I am trying to find a Soundbar to replace my Sony CT100. My main TV is in a echoey room that makes it hard to hear dialogue from TV shows and movies. The room is 20' x 20' with a 20' ceiling, and has a couple of large openings to other rooms. I am working to soften the room, but I really need a Soundbar that will produce clear dialogue. I also want to use the Soundbar to play music in this room. My Soundbar budget is
Banned
I'd look at the Atlantic Technology sound bar, it doesn't have HDMI but is better sounding than the ones you mention for music and dialogue. The 2200 would be better for surround but the 401 you might like better for music. Connect the Sonos with analog connections and you probably won't have any delay between other rooms. If you use the digital connection you might have a delay, depends on the equipment.
1 - 3 of 3 Posts
