Building a small structure adjacent to the main house.
This source shows STC data for various wall types, but doesn't help me understand how effective it will be below 125 Hz.
http://www.toolbase.org/PDF/CaseStudies/stc_icc_ratings.pdf
I'm building a double walled structure, and plan on on inner wall of 3/4" OSB, green glue and 5/8" drywall.
For the main structure outer wall, I was planing on conventional stick walls with standard fiberglass insulation.
Since mass is a key to soundproofing bass (by lowering the resonance frequency of the wall) would a switch to cement block outer walls be substantially more effective to reduce bass transmitted to the main house, located a few feet away?
Another suggestion was filling a wall with sand, but I would be concerned with 1) moisture absorption and mold, and 2) sand leaking out.
