Spades to RCA Jacks help
800 Views 7 Replies 3 Participants Last post by  bobknavs
I have a nice cable run already installed neatly that ends in Spades.
New sub accepts RCA jack. It would be a major deal to re-run a new cable.
1. Is there a Spade to RCA jack connector I could use?
2. Should I bite the bullet and re-wire this PITA run?
3. Any negative with going with a wireless set up?
1 - 8 of 8 Posts
Can just cut the spades off and use something like this:
AILTECK RCA Cable Audio Adapter, Phono Speaker Wire to Male RCA Connector Adapter Plug, AV Screw Terminal solderless Adapter(2-Pack) Amazon.com: AILTECK RCA Cable Audio Adapter, Phono Speaker Wire to Male RCA Connector Adapter Plug, AV Screw Terminal solderless Adapter(2-Pack): Industrial & Scientific
  • Like
Reactions: 3
Thanks that should do the trick!
Just curious:
Cabling that ends in spades? Are those really signal cables, or are they speaker wires? I'd expect those to be speaker wires.
I don't know that the shielding on speaker wires would be inadequate to allow them to be used as signal cables, but I'm not optimistic about that.
They are XLO/VDO ER11 speaker cables. Currently feeding the front three channels and dual subs that I am replacing.
I'm unfamiliar with that. Looks like nice speaker wire, but I doubt that the shielding is up to coaxial signal cable standards. I can't pretend to know that for sure. Feeling lucky?
Is the cable somehow "feeding" the dual subs? (Passive subs? Unusual wiring?)
To answer a question from your first post, the inescapable down side to a wireless adapter is added latency (delay). I've used an Outlaw Audio OAW4 adapter. I didn't attempt to check the delay, but I have read claims of 16 ms. (1ms roughly corresponds to moving the sub 1 foot, 0.3m, farther.) I don't know how much delay the 3700 can compensate for in the Audyssey calibration. I guess it'd be fine if the subs are not farther than 30' (9m) than the main speakers from the listening position. The main problem with e OAW4 was that I had to keep playing with the channel setting (4 choices) to keep a good connection. Interference, maybe. Unfortunately, they use 2.4 GHz, (WiFi, Bluetooth, maybe some cordless phones.)
Yep. passive subs but they are getting replaced with subs that have their own amps.
I was going to use the current XLO/VDO cables which have worked great so far.
The cables don't usually have pickup problems when used with low impedance loads like speakers or passive subs.
The shielding issues with active subs (high input impedance) are quite different. I can't swear that speaker cables won't work, but they are not intended for that purpose. If they're the "zip cord" type (2 conductors, unshielded), I would be pessimistic.
1 - 8 of 8 Posts
