Status
Not open for further replies.
1 - 3 of 3 Posts
I hope this is the appropriate forum to ask the following question, I tried "Home Theater General" and Tweaks and Do it Yourself" and got (2) responses so here goes:
Periodically I hear sparkles/static/pops from my HT system. Why and what can I do about it?
I have the following equipment:
- Lexicon MC8 processor
- Adcom 5500/5503 ? 5x200 watts/channel (next on the upgrade list)
- Rega Planet - CD player
- Panasonic DV-47Ai - DVD/SACD
- Vandersteen 3A sigs L/R
- Vandersteen 2CEs rears
- Vandersteen VCC-5 Center
- M&K 15? sub-woofer
- Panamax 1500/1000+ surge protectors/filters
I have disconnected Cable, DBS and each of the components to try and isolate the problem.
It seems to me that the sparkle is coming from the wall power. I have 2 dedicated 20 amp circuits that I use for the HT system and have Panamax 1500/1000+ that all of the equipment is plugged into.
Not sure what to do next? Any help is appreciated.
Audio-dude
Discussion Starter · #2 ·
Status so far:
1) I bought a Belkin SurgeMaster II Gold (Filters EMI/RFI up 60 DB) and pluged it in between the wall and Panamax.
- The noise/sparkle was significantly reduced.
2) I still haven't unpluged the panamax from the system to see if it is the problem.
- I will do this as soon as I can. Lots of power cables to mess with, much easier to install the Belkin between wall and Panamax.
3) The noise/sparkle was present when my previous processor was in place (DC2 was upgraded to MC-8 recently), so I don't think it is the processor.
4) It could be the amplifier.
My conclusions so far:
1) The power from the wall is probably the problem and will need some more filtering/isolation than either the Belkin or Panamax can do.
2) Panamax is the problem, will need to unplug it from the system and see.
3) The amplifier is the problem. If this is the case, I have a good reason to upgrade.
Any suggestions would be appreciated
Audio-dude
Sounds like an EMI problem to me. EMI is usually caused by electrical
appliances and I have even heard of florescent lights causing it. Your neighbors appliances can even get into the power line and effect your
system. The first thing I would do is start unplugging appliances and other electronics to pin down the source. EMI also radiates through the air and can enter your system that way. I wouldn't be surprised that you could change it by moving your rack to a different location. RS has a cheap EMI filter that plugs into the outlet that you could try and there are also filters that you can snap onto your power cords that may or may not help. EMI can be a real pain to cure as you are finding out and you very well may need better EMI filtration and maybe your Panamax isn't working up to par but it sounds like your on the right track.
1 - 3 of 3 Posts
Status
