Status
Not open for further replies.
1 - 4 of 4 Posts
So I've read countless threads regarding sound cards (I have the M-Audio Rev 7.1) but my needs require simultaneous output of both SPDF and Analog.
Has anyone come across a sound card or other item that has that feature? I would like to feed a local Preamp with SPDF and then stream analog to whole house audio at the same time.
Thanks in advance.
Al
My SBLive does this. In fact you can have DTS/DD on the SPDIF out for a movie and analog out for your audio system from JRMC at the same time...
Discussion Starter · #3 ·
Thanks Mike,
How would you rate the audio quality from the Analog out of the SBLive? Also, is it possible to have both output audio from the same source? Like JRMC or Musicmatch. My needs do not require independent (different) feeds but the same.
It will do the same feed at the same time..
Audio quality is fine for what I am doing.. whole home audio at low volumes.
1 - 4 of 4 Posts
Status
