Status
Not open for further replies.
1 - 4 of 4 Posts
I have a 75ohm coax cable with RCA male plugs. I need to connect one end into my audigy 2 spdif output which is a mini female port......can I just use an RCA female to male mini mono plug?
Craig
Yes.
Yup, no problems. In many respects, digital signal cabling is easier than audio signal cabling. Because digital is an all or nothing game, if you pick up interference in the cable, you'll either get audio drop outs, or, more likely, some weird sound funky sounds (when bits are dropped). In analog, you'll just pick up some noise, which is harder to discern and thus cause people to buy $5,000 three-foot RCA cables (and I am *not* exaggerating -- although I think these people should just give me the five k, as I could easily find a better use for it).
1 - 4 of 4 Posts
Status
