1 - 5 of 5 Posts
Well, after back and forth trying to get my HDCP working between my HTPC and my panasonic prjector, and settled for VGA (by the way, my free month of voice support was worthless)
Now my problem is with my SPDIF connection to my denon receiver. I know that the best I can hope for is a DTS connection, but in the configuratin menu defalts to 2 channel stereo, making my decoder decode a PLIIx signal.
I try to change it to SPDIF it either reverts to 2 channel stereo, or at times Ill get a quick blue screen of dealth, then reboots. The only way around this is to reinstall the program.
Any ideas? I mean DDIIx sounds good, but I have to believe full-bitrate DTS sounds better.
EJ
Discussion Starter · #5 ·
I am also using onboard audio from n asus mb. I'm not sure which model. i'll try installing the latest drivers.
EJ
1 - 5 of 5 Posts
