Status
Not open for further replies.
1 - 2 of 2 Posts
I have a PIII windows 98se with santa cruz turtle beach with spdif out to my sony receiver. Problem: I have stuttering DD 5.1 whenever playing a DVD. Sounds fine when playing mp3's or CD's through the same drive. Does Windows 98se have trouble with ac3 ?
Based on my experience and research it could be a lot of different things. For starters see my post http://www.avsforum.com/avs-vb/showt...hreadid=352986
Your sound card or software audio processing may allow setting of buffer size and/or latency. You may need to adjust these.
If your using Zoomplayer, I would definitely use reclock. Do a search for that.
You also might want to check your CPU load. If your CPU is really bogged down that can cause popping too.
1 - 2 of 2 Posts
Status
