Status
Not open for further replies.
1 - 5 of 5 Posts
Unlike the ASUS MB not including the SPDIF/Toslink "adapter", my Soyo
Fire Dragon did come with it. But I'm having problems getting it going...
My DVD->Receiver Digital Audio currently uses Toslink (optical). So, I
simply disconnected the optical cable at the DVD end and plugged it
in to the Toslink Out - or at least I tried to. No matter what I tried, I
just couldn't get the optical cable to insert far enough into the plug on
the Adapter.
Anybody else have this problem?
So I next tried the SPDIF (rca) connection. This time, a light on my
Receiver indicating "Error/Overload" lit up. In case it matters, my
Receiver is a Denon AVR-3200.
I've heard it said before that there's SPDIF and then there's "SPDIF" :(
I wouldn't be surprised to hear that the SPDIF OUT on the Soyo "adapter"
puts out a 5V signal while the SPDIF IN on the Receiver expects a 1V
signal.
Sound familiar?
Any help would be appreciated...
Try rotating your optical plug 90 degrees and plugging it in. I have a fire dragon and the optical and SPDIF outputs work. The problem I have with the digital outputs is that activity on the computer seems to cause a lot of glitching of the output signals. I finally disabled the onboard audio and stuck a sound card in to replace it.
What DVD/player are you using?
I have the Soyo Fire Dragon w/CMI8738
W2k/SP2->WinDVD3.1-> S/PDIF passthru DD/DTS
First get the Latest Drivers at CMI8738 drivers
Then be advised C-Media setup menu's for
S/PDIF in/output specify #1 and #2 ports
these relate to #1=Optical and #2=Coaxial
So mark them accordingly
I am using the Coax output -> 25foot RG6 cable w/gold F connectors & F->RCA gold adapters.
Accustic Research Video Cable, but any good RG6 quad shielded cable should do.
Sony STR-DA777ES receiver gets S/PDIF on coax and operates just FINE
Also if you are using ATI's DVDplayer....U won't get DD/DTS
they only pass DD thru their own connector
Although someone here has said they got DD/DTS from 7.6ver player??
But I can't do it
PS.. Some Toslink Optical cables come with little PROTECTORS on Fiber Cable end
......U need to REMOVE the Protector before inserting into Toslink Plug, tried mine fits OK
Discussion Starter · #4 ·
Endymion:
Rotating optical plug 90 degrees was tried. Only one (of the 4
rotations) "goes in" at all - it just doesn't go in all the way. I
can get it in far enough into the SPDIF IN, just not the SPDIF OUT
(which is, of course, what I need to do for connection to the Receiver).
Mouw:
Windows Update also successfully updated the drivers from what came
on the Soyo CD.
The "Audio Rack" (including the "Mixer") app(s) were no different on
the C-Media Driver Download site (I tried both them and what came
on the Soyo CD). The MixerApp->Advanced page simply does not
look like what is described in the Soyo Manual. Where the Manual
says I should be able to select SPDIF OUT #1 or SPDIF OUT #2, the
MixerApp->Advanced page only allows the selection between (5V)
Toslink and (0.5V) Co-ax/RCA on the SPDIF IN :-( [I know 5V doesn't
pass on the optical cable :); the 5V is used to power the optics...]
Sounds like you went with Co-ax to your Sony - is the Sony "tolerant"
of a 5V Co-ax Digital Audio input? Apparently my Denon is not :-(
Thanks for the heads up on ATI's DVDplayer. I was actually using
ZoomPlayer but, as I understand it, ZP uses the actual "back-end"
of whatever DVDplayer S/W is installed/selected - and, in my case,
it is indeed ATI's....
Re the Toslink Optical cables having protectors - I was bit by that
back when I first "went optical"... In fact, I actually "tore" the
protector trying (in vein) to "cram it in" with the protector still installed.
I thought I had just destroyed the expensive cable :)
Thanks for the tips... I still am trying to find a version of the MixerApp
which gives the control (over Toslink/SPDIF) of the SPDIF OUT port.
Apparently both ports are "driven" simultaneously and all you are
selecting is the Voltage level sent to the "adapter". And I can't find a
way to knock it down from 5V to the 0.5V expected by the Denon (and
most other Co-ax Digital Audio gear).
I just can't trust the documentation I have. At one point it claims the
SPDIF IN is "auto sensing", but at others requires one to select between
them. This will come into play when my MyHD card arrives and I attempt
to "pass-thru" (via Co-ax Digital "loopback") the (Co-ax only) Digital Audio
from the MyHD thru the C-Media.
Or will I have better luck breaking down and getting an M-Audio Dio or
Audiophile :-( Some have suggested in the ASUS MB with the same
C-Media that the M-Audio was the way to go for a number of reasons.
Many had difficulty getting the "adapter" (which fortunately was supplied
in-the-box with the Soyo even though ASUS chose to exclude it). But one
poster mentioned the C-Media was very prone to dropouts on his ASUS
and he would recommend ditching it. At only $22 for a PCI card holding
the C-Media and connectors, I guess I shouldn't be surprised that it's
quality is suspect :-(
Discussion Starter · #5 ·
More data on selecting between 5V and 0.5V (#1 and #2) on SPDIF OUT...
I forgot to mention that I was able to get (stereo, not 5.1) to pass thru
the RCA at apparently 0.5V levels on the SPDIF OUT to the Receiver by:
- selecting 2-channel stereo on the Speakers Tab
- selecting Enable SPDIF OUT on the Speakers Tab
- selecting SPDIF IN #2
Note that by selecting SPDIF IN #2, it seemed to have the additional
effect of selecting the SPDIF OUT #2 I had wanted. Maybe that's what
they intend. But it does suggest that I might have a problem if I wanted
to use, say, Toslink IN and Co-ax OUT (or visa versa).
I now suspect that I'm not that far off from achieving 5.1 if, as Mouw
suggested, ATI's DVDplayer is somehow preventing the 5.1 transmission.
I'll try other players/versions...
1 - 5 of 5 Posts
Status
