Speaker cables running parallel
289 Views 1 Reply 2 Participants Last post by  tubeguy44
Parallel Speaker wires,
I have to run speaker cables 12 g about 47ft- for rears- under my house ( crawl space) to the opposite wall, then back into the living room. Any issue with tieing the cables together, they would be parallel under the house. Just so i have less wires hanging over head. The area is alo used for box storage.
dave
SF CA
Status
Not open for further replies.
1 - 2 of 2 Posts
your setup will cause no problems....
just be sure to avoid AC power lines that may happen to be in that location as well..... if you have to pass over power lines, be sure to do os at right angles.....
cheers!
1 - 2 of 2 Posts
Status
